TwinTurbo.NET: Nissan 300ZX forum - Not if it is the R12 condenser used in the 09/1992+ TT
Fast300
on August 07, 2013 at 10:18 PM
If you run the r12 condenser adequate cooling will
posted by JMartz
on August 05, 2013 at 01:52 PM
They are the same as the ones used in the later R134a systems.
AC pressure readings normal?
Evan_Wright (Ca)
18:54:47 08/04/13
Re: AC pressure readings normal?
njz
20:31:42 08/04/13
What is the reason to remove the TSV?
JMartz
10:00:09 08/05/13
I don't know the reasoning behind gutting the TSV either.
Evan_Wright (Ca)
12:33:13 08/05/13
JMartz
13:52:11 08/05/13
Not if it is the R12 condenser used in the 09/1992+ TT -
Fast300
22:18:17 08/07/13
the TSV is calibrated for R12
aliaZ
14:49:46 08/05/13
Thanks for the info guys. Next time I need to open up the
Evan_Wright (Ca)
15:26:00 08/05/13
Re: Thanks for the info guys. Next time I need to open up the
aliaZ
16:24:43 08/05/13
That pesky TCA is a bitch of a part. In r134a cars
JMartz
14:04:40 08/06/13
